585,883 active members*
4,732 visitors online*
    Oct 2012
    Building a 5x10 table with HBD gantry
    Hello my name is Cesar, I finished building a 5x10 table with HBD gantry of Mr. Ron and electronics of Cand CNC, I have a Hypertherm 1650 G3 series , pictures of the process.
    Oct 2012
    more pics:
    D
    Oct 2012
    Photos of table, gantry & Electronic Candcnc installed , I had problems with the operation of the electronics was at 220 VAC, but with the support of Mr. Tom appropriate adjustments were made to the controls will operate at 120 VAC.
    Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    Oct 2012
    I have performed the steps according to manual Candcnc see videos:
    THC SENSOR PWM MODULE TESTING
    View My Video
    DYNAMIC SELF-TEST of dTHC MODULE View My Video
    Also we made the test manual cutting a sheet of 3mm the result was good.
    Then with the results was performed automated cutting torch but does not hold the height (it rises), to date there is no optimal cut, I checked connections, mach3 settings, consumables are new, the air, the Sheetcam settings, SETTING UP fOR YOUR Z AXIS aUTOMATIC TOUCH-OFF, checked table ground, I leave photos of the results of manual versus automated cutting cut to give me some idea to resolve the problem.
    Greetings
    Cesar Perez
    Oct 2012
    I returned to install Mach3, these days I carried out tests of cut and I'm happy because the machine is working properly I read the manual candcnc and ready.
    Greetings
  1. Building another 5x10
    By dnelso in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-10-2015, 12:40 AM
  2. building 2 5x10 plasma tables
    Last Post: 10-15-2015, 02:12 AM
  3. Building a machine with a sliding table AND gantry
    By bvz in forum DIY CNC Router Table Machines
    Last Post: 10-02-2009, 02:56 AM
  4. MTC 5x10 Table Customer Service?
    By towertek in forum DIY CNC Router Table Machines
    Last Post: 07-16-2009, 08:45 PM
  5. Torchmate 5x10 table...is it possible to go 6x12?
    By carbidecraters in forum Torchmate
    Last Post: 06-05-2008, 10:32 PM
