I have built a 3 axis stepper motor router running Mach3 R3.043.022 and 2010 Screenset and so far, everything works great.
I have just finished setting up a NC physical home switch close to the +ve limit of each axis (there were physical reasons why I had to use the +ve end of the X and Y axes). The home switches are wired to pins 11, 12 and 13 respectively and this is set up in Ports and Pins as Active Low. When the axes are in the middle of the the stroke (ie, well clear of the switches) the diagnostic window in 2010 Screenset show a blank box beside the X Home, Y Home and Z Home input signals. If I trigger each switch manually, the respective box turns green - so I think all my inputs are working. I have Mach3 set up to home in the positive direction and auto zero turned off (although, turning it on does not seem to help).
When I select the Ref X, Y or Z buttons at the top of the screen, the respective axis moves a short distance in the positive direction, then stops well before it reaches the switch and the axis button turns green, suggesting it thinks it has homed successfully.
I have the soft limits set to very large (and small) numbers so it doesn't think it is out of limits.
Any suggestions?
Thanks!
Dave.
