I'm having trouble writing the code with G03 and leaving a little material for finishing it. 1" 2flute endmill with a 3 " hole tool 13
Then coming back with T13 again and using cutter comp to finish it off.
With X0. Y0. as center of hole?
Yes with x0 y0 as center
Ok, starting with the end mill at the center of the hole. The 3" hole has a radius of 1.5". The 1" end mill has a radius of 0.5". If the end mill moves to X1.0 the side of the end mill should be touching the side of the 3" hole.
Yeah I'm just new to writing the code and don't remember how to code it. I know its with R something and then I draw a blank
You mean G03 X10. Y0. R5.? Like that?
G03 (or G02) are codes for Circular Interpolation. You might want to write that down so you can remember the next time.
Yeah I draw the tool with M06 T13
next line turn on the spindle m03 s500 m08
then turn on ccw circular motion G03?
You need to write an entire program. Not just the lines for circular interpolation. Below is an example program:
O41061 (198-14106 06/15/2012)
(G154 P61 X Y WORK ZERO LEFT BACK OF FIXTURE)
(G154 P61 Z WORK ZERO TOP OF PART)
(HOLD ON FIXTURE)
N10 G00 G90 G17 G40 G80
N20 T7 M06 (0.500 FLAT MILL 3 FLT)
N30 G00 G90 G154 P62 X12.235 Y-4.545 S3500 M03
N40 G43 H07 Z.1 M08
N50 G00 X12.235 Y-4.545
N60 G01 Z-.035 F2.
N70 G41 G01 X12.235 Y-4.275 D7
N80 G03 X12.02 Y-4.06 R.215 F50.
N90 G01 X5.8
N100 G03 X5.685 Y-4.175 R.115
N110 G01 Y-9.575
N120 G03 X5.8 Y-9.69 R.115
N130 G01 X18.2
N140 G03 X18.315 Y-9.575 R.115
N150 G01 Y-4.175
N160 G03 X18.2 Y-4.06 R.115
N170 G01 X11.98
N180 G03 X11.765 Y-4.275 R.215
N190 G40
N200 G01 Y-4.545 F50.
N210 G00 Z.1
N220 X12.235
N230 G01 Z-.04 F2.
N240 G41 G01 X12.235 Y-4.275 D7
N250 G03 X12.02 Y-4.06 R.215 F50.
N260 G01 X5.8
N270 G03 X5.685 Y-4.175 R.115
N280 G01 Y-9.575
N290 G03 X5.8 Y-9.69 R.115
N300 G01 X18.2
N310 G03 X18.315 Y-9.575 R.115
N320 G01 Y-4.175
N330 G03 X18.2 Y-4.06 R.115
N340 G01 X11.98
N350 G03 X11.765 Y-4.275 R.215
N360 G40
N370 G01 Y-4.545 F50.
N380 G00 Z.1
N390 X12.27
N400 G01 Z-.035 F2.
N410 G41 G01 X12.27 Y-4.275 D7
N420 G03 X12.02 Y-4.025 R.25 F50.
N430 G01 X5.8
N440 G03 X5.65 Y-4.175 R.15
N450 G01 Y-9.575
N460 G03 X5.8 Y-9.725 R.15
N470 G01 X18.2
N480 G03 X18.35 Y-9.575 R.15
N490 G01 Y-4.175
N500 G03 X18.2 Y-4.025 R.15
N510 G01 X11.98
N520 G03 X11.73 Y-4.275 R.25
N530 G40
N540 G01 Y-4.545 F50.
N550 G00 Z.1
N560 X12.27
N570 G01 Z-.04 F2.
N580 G41 G01 X12.27 Y-4.275 D7
N590 G03 X12.02 Y-4.025 R.25 F50.
N600 G01 X5.8
N610 G03 X5.65 Y-4.175 R.15
N620 G01 Y-9.575
N630 G03 X5.8 Y-9.725 R.15
N640 G01 X18.2
N650 G03 X18.35 Y-9.575 R.15
N660 G01 Y-4.175
N670 G03 X18.2 Y-4.025 R.15
N680 G01 X11.98
N690 G03 X11.73 Y-4.275 R.25
N700 G40
N710 G01 Y-4.545 F50.
N720 G00 Z.1
N730 (HOME -Z- AXIS)
N740 G40
N750 G00 G28 G91 Z0. M09
N760 G90 M19
N770 (HOME -X/Y- AXIS)
N780 G00 G28 G91 Y0.
N790 G90 X12. M19
N800 M30
Like I said I am new to this and the example you listed is confusing without explanation. I will give it a go then post it and see what you think. Thank you for your input.
Well, saying you are new reads to me as being a student. That means you probably have a textbook to refer to. I am not going to write your program for you. As a student, it is your job to study and learn. Part of learning usually includes a few failures. Good luck on your project.
Your correct that I am a student and this is a project. I don't want yo to write it for me because I wouldn't learn anything. What does the F stand for in line N80?
Nevermind found it in my book!
Cool. Keep up the good work and study hard. Take notes. Writing things down in your own words helps retention.
if you just want info on general CNC programming google is your friend.
there is a wealth of useful info on the net and even full text books on CNC programming available for free if you look.
if you are writing code and want to test it use a simulation program such as CNCSimulator (search google for it)
you will learn much faster if you can see tool paths and what is happening on screen in a simulator.
to program your circle, do a G02/G03 to a diameter of 2.99" (i.e. X1.495) using diameter compensation (G41/G42) then simply go around the circle again using same G41/G42 but this time you go to 3" (X1.5)
here is a very simple example. On the finish pass I changed the depth and I go to a larger diameter to show two separate tool paths. I'm using G42/G2 on the first pass and G41/G3 on the finish pass.
If you google each of the g and m codes in the example and do some reading you will see how this program works. then you will have learned something......
