585,722 active members*
4,222 visitors online*
IndustryArena Forum > CAM Software > CamBam > CamBam engraving problem
    Oct 2012
    I used LazyCAM for engraving PCB isolation paths. Now I tried CamBam and there is a problem I think ....
    LazyCAM did the job with climb miling and in CamBam when I select engrave Machine operation the option "miling direction" is invisible. I can change it only in profile machine operation. Is it possible to engrave with climb mode in CamBam ?
    Tnx
    Sep 2012
    1543
    Engraving is a slot, so not really climb or conventional, therefor not an option.
    Dec 2008
    292
    Select the polyline you want to reverse the engrave direction, then Edit>Polyline>Reverse Then when you generate the toolpath for an Engrave MOP, the direction should change. However, I don't see how changing the direction on an Engrave MOP will effect the quality at all...
    Don
    Feb 2005
    521
    If you set the 'Optimisation Mode' to 'None', then the direction of the source polylines will control the milling direction, otherwise actions like 'Reverse' may not change things if the optimiser decides to go for the next nearest toolpath.
    Perhaps a better option is to use a profile machine operation, so CamBam has a better idea of which milling direction to use. A zero or small tool diameter should keep the toolpaths close to your original lines.
    Another benefit of using a profile operation, you can increase the 'Cut Width' property to mill multiple outlines to improve the track isolation.
    www.cambam.co.uk
  1. Cambam problem
    By crodriguez1517 in forum CamBam
    Last Post: 08-05-2012, 04:04 AM
  2. Replies: 7
    Last Post: 06-12-2012, 01:57 PM
  3. CamBam 3D problem still bothering!
    By kievari in forum CamBam
    Last Post: 08-08-2011, 09:46 AM
  4. cambam problem
    By smitty9306 in forum CamBam
    Last Post: 10-04-2009, 05:43 AM
  5. Engraving/Milling with CamBam
    By GeorgeRace in forum CamBam
    Last Post: 06-27-2009, 08:24 PM
