585,994 active members*
4,600 visitors online*
Thread: G68 Problems
Results 1 to 6 of 6
    Jun 2008
    33
    G68 Problems
    Trying to program a rotation G68 - Meldas M3 Control
    G90
    G17
    G0 x0.0 Z25.0 S1600 M13
    Z5.0 G43 H20
    M98H1000
    G68 X0 Y0 R-60.0
    M98H1000
    G68 X0 Y0 R-120
    M98H1000
    M30
    N1000
    M99
    Involves rotating 6 times at 60 degrees.
    The control gives me a P260 Alarm -
    A coordinate rotation command was issued though it is out of specifications.
    Remedy - Check the specifications.
    Any help would be excellent.
    Regards
    Will
    Aug 2005
    124
    Hey I saw you had no replies so I thought I'd try and help.
    Got out my Fanuc 15M book and what you have written for G68 looks good, but you did not have a G54 or the like there, so.....the machine may be in machine coordinate system, so..... if you are starting from the edge of the machine coordinate system (X0 Y0) and then rotating -60, doesn't that put the coordinate system outside the envelope of the machine's reach?
    Just a thought - because the code looks good. Let us know what you find.
    Aug 2011
    2517
    the machine may not have the G68 option?
    Jun 2008
    33
    Hi
    Many thanks for your suggestions.
    Just relooked at what I posted before and it should of read
    G90
    G17
    G0 G55 x0.0 y25.0 S1600 M13
    Z5.0 G43 H20
    M98H1000
    G68 X0 Y0 R-60.0
    M98H1000
    G68 X0 Y0 R-120
    M98H1000
    M30
    N1000
    M99
    So it should be within its envelope.
    The machine not having the option may a possibility. It used to have it but an engineer came to service it and ended up wiping the control! Most of the parameters were stored but we did have to re-enter quite a few. Would an option be sored in the control or would it have to be reactivated?
    Many thanks
    Will
    Aug 2011
    2517
    On Fanuc from 15 series onwards (or maybe 16 series onwards) usually the options are in the parameters that are punched out. for Meldas I don't know. If you have things that you once could do but now can't do then likely your options are not there. they are just parameters, but undocumented and top secret and by default set to off/disabled to force people to pay dollars for them.
    Feb 2006
    1792
    Just a thought (not very sure): Try G68 with R0. If it still does not work, this option is not there.
    Somebody may PM you.
  1. THC Problems
    By TonyWish in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-02-2011, 02:35 PM
  2. G02 and problems
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 09-20-2010, 05:40 PM
  3. new guy with old problems
    By xxxlmark in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2007, 06:41 PM
  4. 'z' problems
    By bo whipkey in forum Mach Software (ArtSoft software)
    Last Post: 10-11-2006, 02:06 AM
  5. More problems
    By Cold Fusion in forum Gecko Drives
    Last Post: 09-09-2005, 07:19 AM
