586,011 active members*
4,013 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > How to connect Boring head with TTS?
Results 1 to 11 of 11
    Aug 2012
    25
    I own a Boring Head that fits a 1-1/2" 18TPI arbor. I am wondering how I can connect this to a TTS tool holder? Any ideas on this for an off-the-shelf solution?
    I know I could mill up an adapter, but ideally I would like to exhaust any existing options first..
    Feb 2008
    154
    Here is something that should do:
    shars.com - 12quot Straight Shank
    Christian
    Apr 2006
    439
    This one is 3/4" shank.
    Good find concombrefrais
    shars.com - 34quot Straight Shank
    Scott
    www.sdmfabricating.com
    Jan 2007
    1332
    I made my own arbor from a 31802 - TTS Machinable Blank
    for a Flynn boring head by threading in a lathe held in a ¾” 5C collet.
    BTW the Flynn boring head had 1.43-18UN threads so no off the shelf TTS arbor was available.
    Don
    Aug 2012
    25
    Thanks for the suggestions. From what I can see there is nothing "off the shelf". I will need to use a TTS machine blank (I have a few already), put a thread on it and make an adapter. I am not entirely sure how I will do this without a lathe.
    Nov 2009
    4415
    Don't you have a mill? Put the blank in the TTS collet. Use the mill as a lathe. Put a cutting and or threading tool in a vise on the table. Or use a thread mill.
    A lazy man does it twice.
    Jan 2007
    1332
    Quote Originally Posted by spv123 View Post
    You could machine the TTS blank to size with an end mill and then thread mill the TTS blank mounted in a 5C collet chuck mounted on the mill table similar to what I did here except the TTS blank would be held in a ¾” 5C collet instead of an internally expanding 5C collet as shown here:
    Don
    Feb 2006
    1072
    It seems to me that the off-the-shelf shank Scott linked, together with the Tormach off-the-shelf TTS converter or this Tormach off-the-shelf ATC-ready TTS converter would fit the bill.
    Randy
    Jan 2007
    1332
    Sill less expensive to machine your own arbor from a TTS machinable blank at $19.25 (especially if one already has one in hand) vs. $8.20 for the TTS conversion plus $18.95 for the Shars arbor plus shipping from two different places.
    Don
    32432 - TTS Tool Conversion Kit
    Feb 2006
    1072
    I'll refer my learned colleague back to the last sentence of the first post. :wave: (That's intended to be a kind of pointing upward thingie...)
    Randy
    Jan 2007
    1332
    Quote Originally Posted by zephyr9900 View Post
    Randy
    That’s two[sic] bad. As necessity is the mother… missed opportunities to learn single point threading or thread milling on the Tormach.
    Don
  1. Indexable boring bar in boring head?
    By Molochnik in forum MetalWork Discussion
    Last Post: 04-15-2010, 01:36 PM
  2. Boring head help!!
    By wrechin2 in forum MetalWork Discussion
    Last Post: 03-18-2009, 05:51 PM
  3. Boring Head
    By artin51 in forum MetalWork Discussion
    Last Post: 07-10-2008, 11:12 PM
  4. What Boring head should I go with for CNC?
    By SchurrPower in forum MetalWork Discussion
    Last Post: 03-10-2008, 11:07 PM
