585,875 active members*
4,224 visitors online*
    Jun 2012
    Finding Center of Mass (COM)
    To simplify what I'm trying to do, I've drawn a 4 inch circle with a thickness of 0.25 inch. When I analyze the physical properties of the part, the center of mass is not 0,0,0. I'm sure it's a user issue, but I'm not sure what I'm doing wrong. Any suggestions?
    Jun 2006
    3063
    Looks like center of mass is X = ~10-16 (darn close to zero), Y = 0 and Z = 0.125. Since you have the floor of your disk at z=0, and the disk is 0.25" thick, the center of the disk in Z would be at 1/2 x 0.25 or 0.125" Therefore, COM = 10-16, 0, 0.125 seems pretty close to reality to me.
    Does that help?
    Mike
    Nov 2010
    360
    I was going to blame pi and rounding error as this was a cylinder, but I get the same "non-zero" with any other shape. Though, as was already pointed out, 8 x 10^-17 is certainly close enough to 0 to call it zero. I suspect it is just leftover rounding error that should not be getting reported...
    I played with decimal places, precision, etc... but you can only set up to 6 places, and what this is reporting is 12 or more decimal places.
  1. Finding the center of a bore using G55
    By Captdave in forum HURCO
    Last Post: 06-13-2011, 11:13 PM
  2. Need help with finding center of pinions.
    By Coldwave in forum MetalWork Discussion
    Last Post: 12-16-2010, 10:18 PM
  3. Finding center of hole
    By georgebarr in forum Mach Mill
    Last Post: 10-08-2009, 12:27 PM
  4. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
  5. Finding the center
    By Tazzer in forum MetalWork Discussion
    Last Post: 08-05-2006, 06:18 PM
