The first time I have seen a Pneumatic servo valve, and I have used a few hydraulic with satisfaction.
But I would be leery of using a pneumatic due to the compressibility issue?
If I used air at all I would be inclined to use air over oil?
Back in the 80's, Bosch built a CNC machine with all Hyd cylinders in place of servo motors.
I am not sure if they are still around, but there was a manuf. that used a Hydraulic cylinder for positioning that had a stepper motor on the end controlling the spool directly, fed with a step/dir signal. Feedback was need though.
Al.
Albert E.
