You may use CADCAM software to creat program, set toolpath for cutting. Also we need to set feed rates and cutting speeds. Then fasten the foam stock to cnc router. Press "start" button for carvinig automatically.
Then you can stay around it to see. When the foam stock finished, then attach a new one to repeat the process. Once the program settled, then cnc foam router work on it.
OMNI cnc foam router works on foam work reliable. OMNI cnc router uses anti-backlash ballscrews.These ballscrews are with excellent power transmission due to the rolling ball contact between the nut and screws. This type of contact ensures low friction, low wear and long time.
With OMNI cnc router, you would find a cost effective way to meet your requirement on cnc router foam mold making.
