Hi
*I dont understand how can continious flushing work.
If i understand pictures and explanations of wire-edm process, in the gap a delicate process takes place, first iones are bulid up and then plasma channel opens. I imagine if there is flushing(medium is moving) during this buildup, then plasma channel (and its prerequisites - ions) is actually flushed away , and there will never be any spark, or - one will need much much higer voltages to make a spark(compared to situation where dielectric medium stands still and channel building isnt disturbed by flushing).
This is why i supposed one must wait for flush cycle to finish, for dielectric fluid to calm down before continunig with next spark.
Could you explain, how edm can work in continious flush mode?
http://www.manufacturingcenter.com/t...99/1199edm.asp
----the above link, explains some more...
----the flushing accomplishes several things....
1. it is the dielectric between the wire and the work, we maintain this at a very low conductivity...
2. when the pulse finally arcs thru the DI, the flush then removes the edm'ed particles out of the cut
3. it cools the wire and the work
if the flushing did not do these three things, you will be breaking a lot of wire.....
the pulse rate is variable up to as much as 100,000 times a second (100khz) so all that talk of ions and plasma (which does happen) it has plenty of time to do it's thing.... dude, in my 100khz example, ionization occurs 100,00 times a second (it don't take very long!!!!) you are talking about the molecular level of edm, i am talking about usage....if the molecular stuff didn't work, edm wouldn't work. the edm process is still working with constant flush.....i suppose if you forced di into the cut at 10,000 psi you might have trouble......
again, the 3 most important parts of edm is flushing, flushing, flushing.
And one thougt about filtering dielectric(water in this case).
There are magnets(?) to prevent limestone/carbonates to settle on household plumbing.
Could we use such (electro)magnets to filter-capture wery small particles, to use it beside mechanical filtering of flushing fluid?
---standard 3 micron paper filters do the job just fine, some systems use diatonamous earth filters....paper filters are easier....
---you can use magnets, couldn't hurt, i know of no one using that method besides there is a lot of non conductive junk in the water also.....particulate.....
thanks for help
