Hello, everyone,
I'm choosing the power supply for my system, and found this guide by Geckodrive:
Support
Concerning the power supply choice, it says:
"The choice of a power supply is determined by voltage, current, and power supply type (i.e. switching versus linear, regulated versus unregulated, etc.). By far the most problematic and complicated factor is voltage, which will be discussed last.
The easiest factor in choosing a power supply is its current rating, which is based on your motor ratings. A motor control will always draw less than 2/3 of the motor’s rated current when it is parallel (or half-winding) connected and 1/3 of the motor’s rated current when it is series (or full-winding) connected. That is to say, a 6 amp per phase motor will require a 4 amp power supply when wired in parallel and a 2 amp power supply when wired in series. If multiple motors and drives are used, add the current requirements of each to arrive at the total power supply current rating."
It left me with a doubt, though:
If my motors are 3A/phase, and I will connect it in parallel, is my power supply rated current supposed to be:
3 motors * 3 (A/phase) * 2 (phases) * (2/3) = 12 A
or
3 motors * 3 (A/phase) * (2/3) = 6 A
I know this is probably a silly question, but I am quite in this matter.
