Originally Posted by
SBC Cycle
That's weird, what does the simulation do? Also goes through the part?
I set my default Machine Order to Feature. I know exactly when each operation will be called. There are times to change it, when drilling a lot of different size holes using the same spotting drill, but even in those cases I will change my Tool Pattern and remove the "Center Drill" from the Hole feature and just add an operation for spotting to avoid changing the Machine Order.
It's a nice feature if you use the compound operations a lot (Pocket - Rough and Finish Tool; Profile - Rough and Finish Tool). If you tend to use only the "Rough Tool" and leave the "Finish Tool" blank a lot like I do, you will prefer the order to go by feature.
