585,589 active members*
3,567 visitors online*
    Oct 2011
    activated carbon filters
    I have a trotec laser machine fitted with a filtering unit This unit contains a Activated carbon Filter which is no longer working (rubber engraving)
    Is there any way I can make this filter work again?? reconditioning??
    JK/Kuwait
    Oct 2011
    155
    I reconditioned a secondhand HEPA filter that used activated carbon pellets (6X20mm) by replacing the carbon. The pellets were sourced from an aquarium supply store in 25kg bags for USD $130.
    I did notice that the carbon was available on ebay, but postage was a killer.
    I did try to recondition the pellets by cooking in an oven with terrible results. The smell from cooking off the pellets was horrid, probably toxic and would outlast religion; it was that stinky. The paper filters inside were vacuumed clean.
    Feb 2012
    387
    G.WEIKE LASER
    Hi JK,
    we would like to suggest the simple filter see enclosed photo, it is with three layers
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by jorgenk View Post
    JK/Kuwait
    Attached Thumbnails Attached Thumbnails HEPA filter.jpg   filter inside 1.jpg   filter inside 2.jpg
    Jan 2007
    Activated Carbon Pellets
    Not familiar with your unit... but as you get further along you might like to know that activated carbon pellets can be purchased from Ecologix Environmental Systems, LLC: Category
    Good Luck,
    DanR
  1. Y-Axis motor on Tormach 770 just keeps whining when activated!
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 03-18-2012, 01:23 AM
  2. Fanuc OM, Booster not activated at ATC Cycle
    By ThomasS in forum DNC Problems and Solutions
    Last Post: 04-28-2010, 01:53 PM
  3. PLC stops when solenoid valve activated
    By Syphonics in forum CNC Machine Related Electronics
    Last Post: 09-24-2009, 12:59 AM
  4. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-28-2007, 12:23 AM
