586,000 active members*
4,925 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Low resolution curves using "Create Curve on Edges" or "silhouette boundary"
    Mar 2007
    86
    Hello All,
    Often I get very jagged interpretations of my parts' edges when I create curves from solid or surface edges. They show up as facets when doing 2D and 3D contour toolpaths, not smooth lines/arcs. It is not my native 3D file's resolution as I have the problem whether importing an iges or native Solidworks file. Is there a place to increase the resolution setting for this problem?
    I thank you in advance,
    Jeff
    Mar 2007
    86
    BTW- not my filter settings in toolpath.
    The actual curves have low res.
    Apr 2003
    3578
    You are just talking about how looks on the screen correct?
    Cadcam
  1. What causes "rough" edges when laser cutting acrylic?
    By shobley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2011, 12:19 PM
  2. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
