585,959 active members*
5,035 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Ridgid Tapping on Okuma MB-56VA
Results 1 to 9 of 9
    Sep 2007
    133
    HI all, My mahcine is Okuma MB-56VA OSP-100M
    now Been using it for over 5 years and its all good.
    however when it comes to ridgid tapping I want to Peck ridgid tapping
    the mahcine will peck
    if I write this:
    G83 X0 y0 R2. Z-30. (this will ridgid tap all the way down non stop)
    however if I want to ridgid peck tap to z-30
    then i have to put
    G83 x0 Y0 R2.0 Z-10.
    G83 Z-20
    G83 Z-30
    this will peck to z-30 no problems..
    so My Question is I dont want to write G83 everytime infront of Z
    so i want it to look like this:
    G83 x0 Y0 R2.0 Z-10
    Z-20.
    Z-30.
    is there a parrameter that can control the Z movment to peck like this?
    bassically if i run it without the G83 infront of the Z- then it will ignore the numbers and only go to z-10. which is the only the first line..
    anyone know whats the paramerts for the ridgid tapping cycles?
    thanks
    Dec 2008
    3109
    Query:- G83..... what M-code do you use for peck drilling with full retracts ??
    I think your #3 & #4 buttons on the keyboard have been swapped over.
    The G-code is "modal", meaning it is active until changed by another G-code from the same group
    ie G0, G1, G2, G3 are in one group
    G17, G18, G19 are in another. A code from one group will not alter another code from a different group
    So, there is no parameter to alter, just state the code on the 1st peck ( hole ), then do the pecks for that hole----you could put the pecks into a subroutine after the M30 if you had many holes to tap & use a call statement----remember to re-state the 1st peck level as all the addresses within the cycle are modal as well
    ie
    Code:
    G95 G84 X0 Y0 R2.0 Z-10. F2.0
    CALL OPECK
    X10. Y0. Z-10. ( next hole, must specify the 1st peck level again)
    CALL OPECK
    G80 G94
    M30
    OPECK (Tapping Pecks)  <-- yes, you can put comments here, they do help
    Z-20.
    Z-30.
    RTS
    G95 is feed per rev, so the feedrate is the lead/pitch of the tap ( saves remembering to alter the feedrate if you do change the programmed RPM )
    ---also look to see if you have the G284 function - also a rigid tap cycle
    Sep 2007
    133
    hi, and thanks for repling.
    my peck drilling cycle is:
    N4 G83 X0. Y0.0 Z-70.1 R5.0 Q5.000000 F60.0 M54
    you are right, my Ridgid tap cycle is G84...
    but my problem is that if I use
    G84 x0 z0 z-10
    z-20
    z-30
    then the cycle will ignore the Z-20 and Z-30 and only will read the Z-10..
    and not Peck, but if I put G84 infront of it then it will peck..
    should be able to just put the number there without me using G84 all the time..right? but it wont, so i though there might ba parameter that can control the behavior of the G84 cycle somewhere..
    thanks.
    Nov 2006
    174
    On our P200M control peck tapping is G282
    G95 G282 X0 Y0 Z-30 R2 Q10 F2 S400 M53
    Sep 2007
    133
    I found that
    N4 G282 X-120.0 Y0.0 Z-10.0 R2.0 Q2.0 F800.0 M54
    is doing pecking and it seems to reverse the spindle on going up, however I couldnt see
    if it was real ridgid tapping or not due i did it in air, so not sure if its going to
    break in metal or not...
    Nov 2006
    174
    The spec sheet I have calls for an S code in the G282 block.
    G282 is Rigid tapping. Why wouldn't it be as stated.
    Don't be scared. Try it
    Apr 2014
    44
    Re: Ridgid Tapping on Okuma MB-56VA
    hi, i have a question about that machine and the rigid tapping function of it. is there a delay at the start of every hole to tap on that specific machine?
    Sep 2007
    133
    yes you can delaye it by G code:
    G04 P15 (for 15 seconds)
    Apr 2014
    44
    i started a new thread for that topic. http://www.cnczone.com/forums/okuma/...a-tapping.html
  1. Ridgid tapping on Fanuc
    By peaceandcalm in forum Fanuc
    Last Post: 10-25-2020, 12:11 PM
  2. OKUMA MB-56VA 4 axis post
    By peaceandcalm in forum Post Processor Files
    Last Post: 05-16-2014, 01:44 AM
  3. Replies: 7
    Last Post: 08-10-2013, 02:25 PM
  4. Ridgid Tapping 1/4-20
    By southernexplore in forum Haas Mills
    Last Post: 10-16-2009, 08:45 AM
  5. probing in a okuma 56va
    By raymond.baker8@ in forum Australia, New Zealand Club House
    Last Post: 10-07-2009, 03:34 AM
