586,011 active members*
4,057 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Where can I buy Nichrome wire from?
Page 1 of 3 123
Results 1 to 20 of 51
    Oct 2004
    16
    I am looking for Nichrome 6 ohm/foot wire.
    I tried find it from HobbyLobby, Home depot, etc..
    Ebay doesn't have 6 ohm/foot.
    Anyone can help me?
    May 2005
    362
    Nichrome wire is commonly used in packaging machinery to seal plastic bags. A current is applied to it and it heats up and used to seal the bag. We have rolls of the stuff to replace the wires in the sealing bar when they get old and break. Try an industrial packaging supply house. You are looking for the NiChrome wire used in a machine called a "Drop Sealer"
    Mar 2005
    1136
    ihkim, I don't know what the resistance is, but a of people use guitar strings, cheap and available at any music store. high e = .25mm. guitar strings have a high nickle content
    Jan 2004
    190
    try Aircraft spruce and specialtys I think, I have got some from them for cutting foam
    thanks Kenneth
    www.lambertsrc.com
    Sep 2003
    1113
    here is a site I came across today - wasn't even looking....well I was looking for some foam cutting ideas - good looking machine at the site too.
    http://burnsmodelaircraft.com/index.htm
    May meet your spec? Worth a look.
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    332
    Pelican Wire
    Jun 2005
    232
    May 2004
    314
    www.demandproducts.com
    they sell nicrome wire by the 50 or 200 foot rolls, if you need much less than this, email me and i will sell you some off of my roll
    Ed Rees [email protected]
    Oct 2005
    1238
    Pottery Suppliers For Nichrome
    Pottery & glass working kilns (of the electric variety) use nichrome wire in the elements.
    Check in your area for a large supplier. They usually have the wire available by the foot.
    Sep 2003
    1113
    Just a thought - what about using stainless steel wire leader (shark leader)? Too much resistance or?? Thouht I'd seen that suggested or sold for the same purpose. Is there any problem using it as a substitute?
    Thanks Jim
    Aug 2004
    2849
    High Seas.....I suspect that using the stainless would not work......well okay, maybe if you supplied a 100 amps or so.....Nichrome wire is the way to go and all the old fashioned appliance repair places have it.
    Oct 2004
    16
    Quote Originally Posted by erase42
    It is so nice of you. But I am interested in purchasing 50' roll.
    Thank you again.
    Kim.
    Oct 2004
    16
    Thank you guys,
    It helps me a lot.
    Kim.
    Jul 2003
    51
    If you haven't purchased the wire yet you might look at McMaster-Carr they are very fast and hassle free. I haven't found them to have the absolute lowest prices on anything - but they have just about everything and are very professional.
    Unless demandproducts is selling the best wire in the world (should have specs) they may be selling it for several times its retail value. -could be wrong.
    Oct 2005
    267
    Found a supply of wire that is better than Nichrome: http://webpages.charter.net/mnemesh/ Click on the Iconel Wire button on the left. You can find specifications on the internet by doing a Google search.
    Mar 2006
    21
    Feb 2005
    36
    I tried inconel wire .It is really nice .It doesn't change it's properties after heated up. I strongly recommend it for cutting wing cores .
    Murat..
    Oct 2005
    267
    Connections
    Quote Originally Posted by rceebuilder
    Murat..
    How do you connect it up and did you find it hard to bend? How about a photo or two of your machine?
    Feb 2005
    36
    yes it is a little bit hard compare to nichrome wire. I hanged about 5 kilos weight to tighten it.Here are the photos
    May 2006
    6
    I haven't used Nichrome, but I scored some .020 steel roll at walmart , its the stuff that is used in mig welding (wirewelders) 2 pound for 8 bucks (dont know haw many feet though), the stuff looks like it will last for ever, and heats up/down preety good with a 5 amp battery charger/w dimmer control
Page 1 of 3 123
