585,930 active members*
3,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-4 vs VF-5: Z travel woes...
Results 1 to 6 of 6
    Jan 2011
    51
    Well, crap. Just got in a brand new VF-5 and we moved the programs and fixtures over from the VF-4 to run a job and kept getting Z overtravel alarms. Just figured out that the spindle face can get to within around 4" on the VF-4, but only around 8" on the VF-5! I fudged the parmeter that controls the max number of steps from 26,638,271 to 27,470,720 and bought myself an extra .75" of travel, but that didn't help much. Any more than that gave me a servo error alarm. I'm guessing the idea was that with the VF-5 being a bigger machine people are expected to cut bigger parts on it so getting close to the table wasn't a priority. Unfortunately I'm cutting the same sized parts, just more of them on the larger table. I know there's no fix for this other than to make my fixtures taller or use longer tool holders, so I'm just posting this as a warning. Also posting it in case my little parameter fudging is going to cause my machine to explode, and maybe a Haas guy will warn me before it happens.
    Dec 2008
    717
    That is a bummer. Guess you should have checked the specs first
    Haas VF-5/40 | Haas Automation, Inc. | CNC Machine Tools
    :stickpoke
    Tim
    Feb 2009
    6028
    If your getting servo errors now at the bottom, you will blow something up. Ballscrew or something else is now binding.
    I would set the the params back to where they were originally. Underthetire is right, the ballnuts could be at the end of the travel and binding. You want to leave some breathing room for fast decelerations.
    Most machines of this size class have a similar spindle-nose to table minimum distance. I agree it's pretty annoying, but it is what it is.
    -Sol
    http://www.orangevise.com
    Jul 2005
    12177
    Yes, change your maximum travel parameter back to what it was.
    It is not likely anything bad will happen the way you have it when the controller is doing a rapid or feed move because it keeps track of the axis position.
    HOWEVER if you rapidly spin the jog wheel to bring the Z axis down it can overshoot and if you don't have a bit of room for some overtravel you can cause damage.
    Don't ask me how I know this.
    Jul 2005
    64
    Mark,
    This is why I bought the VF4. I wanted the bigger table a 5 represented but the spindle nose to table was to much. There is an answer for that from Haas and they sell a table to put on your table to reduce the height. Around $3600 as an option if I remember right.
    I also figure that what I gained in table size I would lose in cut speed productivity with the VF5 compared to the VF4.
  1. AVHC Woes
    By pirateducky in forum Torchmate
    Last Post: 07-22-2011, 01:39 AM
  2. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  3. Programming woes!!!!
    By bunyanblueox in forum Centroid CNC Control Products
    Last Post: 01-31-2009, 06:20 AM
  4. RE- My woes with CNC......
    By kbillan in forum Taig Mills / Lathes
    Last Post: 01-16-2009, 11:22 PM
  5. Bob CAD woes
    By Mr. LocoMartin in forum BobCad-Cam
    Last Post: 01-25-2008, 09:18 PM
