On DMC 64V Linear is a table with 850x600 table. Software switch on X-axis is on 640mm (Under the parameters limited by the value of x+641500). When I type velue x+650000, then on screen is not message "X-axis limit" (vhen I drive mashine past the 640 mm), but still no go ower the 640 mm plus on the X-axis. The machine I get an error like that is in the area of ​​tool changes.
Is it where the parameters are what parameter to change the area of change tools to go beyond the 640 mm?
I need more space on the X-axis, but I cant not move the boundaries of X axis.
Physically, the spindle when changing tool slides for at least half a meter further than 640mm. Whay by working this is not possible?
