Any thoughts on getting my M32 t0 communicate with MultiDNC software.
I've stepped through set-up on both ends, tested and double checked all connections, settings, etc. What might I be missing?
Some one at Mazak couldn't count right. Check to make sure the computer is on 7 stop bits and the mazak is on 8.
Make sure the cable works on different machine.
Did it ever work.
First try to see if you can receive a program.
I have done this 2 years ago i do not remember all the buttons
if you can post screen shoot step by step that would refresh memory.
I even had a pocket pc hooked up to it to transfer data but only in MAZATROL G-CODE LIKE FORMAT --------- no its not fanuc format.
Bunch a gcode with numbers and letters.
