585,585 active members*
4,642 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 109JB's G0704 conversion (pics now, plans soon)
Page 3 of 3 123
Results 41 to 49 of 49
  1. #41
    1943
    Re: 109JB's G0704 conversion (pics now, plans soon)
    No real performance benefits at present. The uno and the nano have the exact same specs. The nano is just physically smaller. The Mega 2560 has more I/O and more memory, but they aren't utilized in GRBL. At least not yet. So, for right now it makes no difference unless you want to modify the GRBL code as others have done.
    John
  2. #42
    Feb 2007
    4553
    John,
    Microcenter has the Uno boards on sale for $5.99. Tomorrow I will be picking up a few for testing.
    http://www.microcenter.com/product/4...o_R3_MainBoard
    Thanks again,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  3. #43
    Jul 2012
    64
    Very nice build so far. I really like the mounts for the ball nuts. Great idea. You must have done this before. I am about a year into my build it seems and I bought hoss' plans. Still trying to get this together. Thanks for sharing your work.
  4. #44
    1943
    Found and corrected some issues with my GUI. Here is the new download link.
    https://dl.orangedox.com/EqqZYCIOLOe...0Interface.zip
  5. #45
    1943
    I've decided to sell the G0704 from this build thread. The classified posting is at this link
    https://www.cnczone.com/forums/newly...ml#post2411806
  6. #46
    Jan 2018
    1516
    Hi mate.
    I don't suppose you have drawings/measurements or anything of the back of the head do you?
    Need to know the size of the center circle hole and the distances of the 3 bolts so I can make a small spacaer.
    I really don't want to have to remove the head, measure, then replace it so I can cut the part.
    Tia.
    Daz.
  7. #47
    1943
    Quote Originally Posted by dazp1976 View Post
    Hi mate.
    Tia.
    Daz.
    No I don't. Sorry.
  8. #48
    Sorry to hear you are selling! I hope all is well!
  9. #49
    Dec 2020
    Quote Originally Posted by 109jb View Post
    Well, I finally sold my round column Harbor Freight mill (link) last week so it is finally time to get my G0704 up and running on CNC. I had measured, designed and made all of the parts for the G0704 on the round column mill, but had to wait until it sold so that i could buy the steppers, drivers, and BOB. I got all but the BOB and now have the mill mostly assembled. It has gone together and been taken apart probably about a dozen times over the past few months, but hopefully this is the last time before it makes some chips of its own. I already have some parts I need to make for my other numerous hobbies.
    The summary of the conversion and the components, along with some future plans is as follows:
    - Automation Technologies (Keling) 570 oz-in steppers on X, Y and Z
    - Automation Technologies (Keling) 6050 drivers
    - 48V 13.5A Dell server power supply
    - Chinese manufactured parallel port BOB
    - Salvaged 2.6 GHz pentium 4 PC
    - USB Game controller for a pseudo pendant
    - LinuxCNC (I am going to give Mach3 a try this time around though)
    - Thompson rolled ballscrews with double nuts on all axes
    - Angular contact bearings on all ballscrews
    - Machined aluminum end plates on all axes
    - Lapped ways on all axes
    - Way lube system started (ready to plumb)
    - Home/limit switches planned using proximity switches
    - 4th axis planned (already have a 6" rotary table)
    - Possibly a different spindle motor and belt drive
    As for the machine tour, I'll start at the end and then go through the conversion.
    Below is a picture of how it sits in the barn right now. Well almost. In this picture I had forgot to put the Z-axis way cover on which has since been corrected.
    Below is a pic of the Z-axis ball screw setup. I found that the Thompson ball screws are too hard for the lathe tooling I have to be able to cut threads, so I welded on a chunk of 5/8" diameter steel rod on the end of each ball screw and then proceeded to machine that. The threaded end just has a 12mm straight section followed by a 12mm fine pitch thread on it, That's all. You'll see why later. In this picture you can see that the double ball nut arrangement has been installed.
    Here is a closer view of the double ball nut. Starting from left to right in the picture. First is the "fixed" ball nut that is threaded into the aluminum slide mount the attaches the Z-axis slide. This part is in 2 pieces with a tight fitting key. This was done that way so that it would fit through the top of the column while assembled on the screw. The second ball nut is next. Its threaded end is simply protruding into a 1" diameter bore in the end opposite of the slide mount. on the right end is an aluminum plate that has a stack of wave washers between the plate and the ball nut This plate is attached to the slide mount with a pair of 1/4" diameter bolts to provide preload to the ball nuts to eliminate backlash. The preload on all axes is about 120 pounds.
    Here is the column top cap with stepper standoffs and the end of the ball screw. On each of the ball screws, I have a wave washer in the assembly stack to provide preload to the angular contact bearings without having to monkey around with double nuts.
    Here is a good service for helping with essays: https://pro-essay-writer.com
    Here is how my motor couplers are made. These are home brew Olham couplers made from aluminum with a HDPE puck. The motor side just has a 3/8" reamed bore with a 1/4"-20 set screw to lock it on the shaft. The ball screw side has a 12mm threaded bore and after threading, I split the coupling. I have two 1/4"-20 SHCS that clamp the coupler onto the threaded end of the ball screw like a split collar. With the threads, I can put the SHCS's in just snug and thread the coupling half onto the ball screw. I then tighten it up to compress the wave washer for preload and then lock the SHCS's. Seems to work great. We will see how it works in operation soon.
    Here is the y-axis ball screw setup. Same principal as on the z-axis, just different geometry. Also, I cut the threaded end off of the floating ball nut to reduce the length of the assembly.
    And the Y-axis motor mount/thrust block. Same angular contact bearings, but here, I have a little aluminum puck with a recess that acts as a pseudo labyrinth type seal to keep crap out of the bearings. The angular contact bearing on that side protrudes from the mounting block a bit to accommodate the seal/puck. You can see on this one that the wave washer is between the puck and the coupler.
    Carriage installed, Y-axis hooked up, and X-axis screw in place.
    At this point the table is installed and the end plate at the floating end of the ball screw is installed. On the floating end of the x screw, I did machine a 12mm diameter into the ball screw to fit the bearing.
    And the opposite end awaiting the coupler and motor.
    Here are a couple pics of the Y and Z axis with motors and couplers installed. Somehow I didn't get a picture of the X axis at this point.
    Well that is about all for now. I think this setup is going to work pretty well. Each axis moves very smoothly after lapping. Next is to wire up the electronics. I already have the PC set up for dual booting LinuxCNC and Windows XP Pro with Mach3 and LinuxCNC installed. I am still waiting for the BOB to arrive but will have the power supply and drivers temporarily wired for testing tomorrow. As soon as the BOB gets here I can start moving under CNC control.
    I will post my plans of the parts for this conversion when I get it tested and have a chance to clean up the drawings a little.
    Once the mill is up and running I plan to convert my little 9x20 lathe to CNC.
    Enjoy,
    John B.
    This looks great, I wish I could afford conversions like this, but money is tight as an apprentice.
Page 3 of 3 123
  1. G0704 CNC Plans
    By mrcodewiz in forum Benchtop Machines
    Last Post: 02-23-2016, 02:09 AM
  2. G0704 BD Tools build pics
    By Fastest1 in forum Benchtop Machines
    Last Post: 10-31-2014, 05:08 AM
  3. G0704 ballscrew mount plans
    By bollero in forum Benchtop Machines
    Last Post: 03-20-2014, 04:22 AM
  4. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  5. RFQ A few parts from Hoss G0704 Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 10-21-2011, 09:13 PM
