585,996 active members*
4,702 visitors online*
    Nov 2012
    139
    Source for 26 wire ribbon cable assembly
    Maybe this is a dumb question, but I'm pulling my hair out looking for a pre-made ribbon cable (with IDC connectors) that uses all 26 wires, not 25 wires. I can find 25 wire cable by the foot, but I can only find 26 wire cable in 100' spools, and I don't need 100'....or 50'....or even 5'. Specifically I'm just trying from JP33 on KStep to a breakout board in my controller box.
    24221
    Buy Ribbon cable by the foot from Digikey.
    Even if you have to buy wider, just strip off what you need and buy the IDC ends, very simple to apply and assemble in a small vise.
    Al.
    Albert E.
    Oct 2012
    44
    Al.
    And Aren't floppy cables 26 pins with an IDC header already attached?
    Nov 2012
    139
    Al.
    Hmmm...I must be going soft for not having thought of that. I have a local electronics shop that carries 30 wire ribbon cable by the foot. Done. Great idea
    Thanks.
    24221
    Quote Originally Posted by nickcornilsen View Post
    They do, but IBM screwed it up with their stupid address swop over, a section is reversed.
    Al.
    Albert E.
  1. Replies: 1
    Last Post: 09-30-2012, 07:25 PM
  2. Another source for the mini mill head assembly?
    By turboedgs in forum DIY CNC Router Table Machines
    Last Post: 05-02-2011, 10:02 PM
  3. Haas Cable Assembly Connectors
    By Mr. Technical in forum Haas Mills
    Last Post: 06-03-2010, 09:14 PM
  4. Need a source for this bearing mount/assembly
    By SteveL in forum Linear and Rotary Motion
    Last Post: 09-18-2006, 01:43 AM
  5. Spiral Cable source?
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 12-17-2005, 04:39 PM
