585,931 active members*
3,576 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Can anyone tell me the current cost of MasterCam for a 3 axis license?
Results 1 to 17 of 17
    Nov 2012
    7
    I heard there may be different levels of 3 axis, so I think I would want the best/most advanced level for cutting surfaces / molds / dies etc.
    Location is Michigan if it matters....
    Thanks!
    Dec 2008
    3109
    Learn what is available HERE at CNC Solutions for milling
    you have choice of :
    Mill Level 1
    Mill Level 2
    Mill Level 3
    MultiAxis
    ---- add-ons to any of these levels can be "SOLIDS" & "FULL 4 and 5 AXIS MACHINING"
    If you are doing molds etc, by ustilizing surface machining, then Mill level 3 would be the starting point.
    You can use a 3rd party CAD to create your solid models, but that can (at times) be a *****.
    If you don't have SOLIDS, then you cannot move, modify, create anything within Mastercam
    Multiaxis is for programming rotary movement. using the rotary axes for (3+1 or 3+2) positioning only.
    ie rotate to an angle then run a 3 axis or 3D surfacing operation.
    The full 4 or 5 axis option allows programming to use the machine it's fullest capability
    IMO, your price to hunt for is for Mill level 3 with SOLIDS, that is if you don't have a 4th axis,. It can be added on later if your capability changes.
    PS- also investigate the possibilities of Mastercam for Solidworks, You must also have purchased Solidworks beforehand. This mastercam does NOT have all the same functionality as a full blown Mastercam version
    Dec 2010
    I have Mcam X6 Mill level 3 Lathe level 2 Solids and I have 15,000 vested.
    If you just want Mill with 3d options I would say around 10,000 to 13,000
    Apr 2006
    3206
    Quote Originally Posted by Superman View Post
    Mill Level 1
    Mill Level 2
    Mill Level 3
    MultiAxis
    THANKS FOR THE AD.
    THE QUESTION WAS HOW MUCH????????
    May 2004
    4519
    I thought you knew. The price of MasterCam is negotiable. The resellers do have a minimum they have to charge to break even. But that price is never, ever to be published. After that it becomes a game whose vise grip pliers can squeeze whose nads the hardest. The resellers have bigger pliers in almost all cases. ROFLMBO
    Apr 2006
    3206
    Quote Originally Posted by txcncman View Post
    Which is precisely why I responded as I did.
    The negotiable nature of the product turns the resellers into nothing more than used car salesmen.
    If you pay more, do you get a better quality of tech support? Extra C-hooks? A free extra dongle with every purchase of 4 seats?
    My situation got me a very good price, and I can't say enough good things about my reseller... BUT..... If yours is a dick? Why should you get any less than what anyone else gets?
    /grousing off
    Dec 2008
    3109
    Quote Originally Posted by fizzissist View Post
    THANKS FOR THE AD.
    This was NOT an ad. & why the attack...you're NOT the person asking for the info. You have been around for a fair time, hung out in this arena to know how it all works.
    You have to know what it is, that you need to ask for....
    The OP more or less asked...How much is a car?
    -- without knowing what he wants to do with it.
    - knock out a deal, have training, posts, support etc all written & locked into a contract. So that all parties meet their obligations - if any part of the deal is not completed ( by a set timeframe) to the other's satisfaction, then there is the avenue of voiding the contract & receiving a refund on the original outlay.
    You can go and spend $35K, get all the bells & whistles, and be totally dis-satisfied that being a newbie that you have just been taken to the cleaners. Or get the most basic Mill level 1 for $10K, & be just as pissed off that you still have to fork out more $$$ just to be able to do a toolpath on a solid surface. ( prices are guestimates )
    I didn't give prices that were applicable to my part of the globe ( I'm an ocean away & use a different currency ). I'd guess that the U.S. would have the lowest prices, I heard that Canada also has a big markup. So I deliberately did not give any costing for those reasons.
    Fizz - How come that you didn't put up the prices ??
    - you probably have more accurate costings than anybody else
    Apr 2006
    3206
    The original post was:
    "Can anyone tell me the current cost of MasterCam for a 3 axis license?
    Thanks!"
    Your response was:
    "Learn what is available HERE at CNC Solutions for milling... etc.."
    ---Little doubt he's already been there, seen that, looked for prices
    He said 3 axis. He said surfaces / molds / dies etc. He said Michigan (which you say matters).
    You ultimately said: "IMO, your price to hunt for is for Mill level 3 with SOLIDS"
    I've been around long enough to have seen time and time again people asking how much and not getting a firm answer from a "reseller". That said, I'll ask... since you were offended by my not being the original inquirer...
    How much is a single commercial seat of Mill Level 3 with Solids in Michigan for X6?
    Nov 2012
    7
    Quote Originally Posted by SpectraBrad View Post
    Thanks for the input guys, it is helpfull to learn about the options, the whole process can be daunting, and in my case the reseller may or may not have told me I didn't need the full blown solid modeling options etc. I don't remember actually. It is hard to get everything straight while trying to figure out if a product is going to work for you or not. Anyways, it really helped me to learn that I might be able to strip off some of the cad functions as I really do not need them. And based on the price above I am being quoted something way more than I need, I am being hit up for 18,500 I believe but that included the first years maintenance....
    Thanks for the help, if anyone else has any specific numbers please share!
    Apr 2003
    3578
    I do have the numbers here for Cali but Sorry I am not allowed to post it on line.
    Enough said.
    Cadcam
    Oct 2006
    85
    I purchase X6 earlier this year. Mill level 1 with solids.
    Mill level 1 > $6,195
    20% discount -$1,239 (advertised "limited-time" offer)
    Solids > $1,150
    Shipping = $20
    Tax = $442.69
    Total = $6,568.69
    May 2012
    180
    Just ordered Mill level 3 + solids + Multi axis + Sim multi + 5 days training.
    All the nuts and bolts.
    £13K
    Just to clear things up.
    Thats a UK price.
    http://bit.ly/UJnZjK
    Apr 2003
    3578
    What people need to remember as it is different in different parts of the world.
    Cadcam
    Aug 2013
    10
    Re: Can anyone tell me the current cost of MasterCam for a 3 axis license?
    So... the straight answer is... disregarded?
    What can we expect to beat them down to?
    Jun 2017
    5
    Quote Originally Posted by metalmansteve View Post
    Solids > $1,150
    Shipping = $20
    Tax = $442.69
    Total = $6,568.69
    Solids? What CAD software is associated with/incorporated into Mastercam? Is it Solidworks? Any insight is appreciated.
    Apr 2003
    3578
    Quote Originally Posted by tnosmelc View Post
    There is no other cad inside Mastercam. But you can get Mastercam 4 solid works as a cam add-on.
    And the pricing be shown is incorect.
    Cadcam
    Jun 2017
    5
    Quote Originally Posted by cadcam View Post
    Thanks CADCAM.
    I replied to one of your posts in regards to Mastercam U and Fusion 360. I'm looking to get into CAD/CAM programming and any insight would be greatly appreciated.
  1. Cost of Mastercam
    By FMJ in forum Mastercam
    Last Post: 06-03-2015, 08:33 PM
  2. Esprit vs. Mastercam cost
    By BROCD in forum Esprit
    Last Post: 01-27-2014, 01:24 AM
  3. What does Mastercam cost?
    By Technical Ted in forum Mastercam
    Last Post: 03-27-2009, 03:12 AM
  4. Low cost CAD/CAM Solution with MasterCAM style and feel
    By native34 in forum Uncategorised CAM Discussion
    Last Post: 03-16-2009, 02:21 AM
  5. Mastercam license
    By omars in forum News Announcements
    Last Post: 01-18-2008, 01:20 AM
