585,982 active members*
4,669 visitors online*
    Nov 2012
    Motor Tuning Settings
    Hi, I'm also having problems coming up with the correct setup for a cnc plasma/Router table I want to build. I'm struggling with working out the right timing pulleys to use and I'm not very familiar with inches. I need a reduction pulley to give me more torque because of the weight of my Gantry. Currently I have these options in mind.
    620oz stepper motor from candcnc
    5mm pitch 12 teeth pulley on motor with a 5 pitch 30teeth timing pulley which I'm hoping will increase my torque a bit, but my main problem is all the settings that need to be entered into the Mach 3 Motor tuning interface. I've read the manual, but it still confuses me.
    I apologize if I'm hijacking a thread, but I'm new to cnczone as well, heads up for any advise I can get.
    Are you using rack and pinon, or screw drive?
    What drives are you using?
    How fast do you want to go?
    How much weight are you moving?
    Nov 2012
    I'm intending on using a Timing Belt with Pulleys, I'm not sure how fast I can go, but probably not too fast considering I want to do Plasma cutting and Routering. I'll be using 620oz-in Hybrid Motors from www.candcnc.com, and the Gantry weighs 85kg including router. I will have a 4 axis system, but only really need 3 motors on the axis's with the hopes of perhaps running the 4th motor on the Y axis too. Table dimensions are 3m x 1.5m
  1. Stepper Motor Tuning / Settings in Mach3
    By Rob37 in forum Controller & Computer Solutions
    Last Post: 11-04-2010, 02:59 AM
  2. what are your motor tuning dialog settings at?
    By surrealism in forum Taig Mills / Lathes
    Last Post: 06-18-2010, 10:35 PM
  3. motor tuning settings on new vfd
    By billmiller in forum Shopmaster/Shoptask
    Last Post: 05-28-2010, 11:05 AM
  4. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  5. Oscilloscope settings for G320 servo tuning + trouble
    By giorgiocnc in forum Gecko Drives
    Last Post: 12-10-2005, 11:44 PM
