Originally Posted by
flatform
I haven't really understand what is the Q value, when i leave it 0 and change only the Step Down value, ie. 5mm, when running the simulation i see something logical, the drill advances 5mm at a time, when using Q only the drilling goes down in one step. Another thing is that with the options you see i get a crash warning on each hole, in appx. the middle of each depth, while running at Z with feed rate not rapid, present in al the holes except the last one, in both 3x and Haas_3x, any clue??
"Q" is the peck or increment amount in Haas canned drilling or milling cycles. It is how much the drill goes down with each peck or the step over amount in milling cycles like G13.
It is fine to let your CAD system write complicated code, but you REALLY need to understand your basic cycles and G-Codes. You should be able to know what each line of code is going to do or you will find yourself in big trouble.
If you are just starting, writing a circle or radius move, for a corner say, is fairly intimidating, but writing a simple drilling cycle is pretty damn easy. If the software is asking for the "Q" value and you have no idea what that is, you will soon have issues.
Study your manual and learn the basic G and M codes. Canned cycles like G81, G83, G84, G85, G12, G13-----Learn what they are. In learning them, you will learn the other codes of the canned cycles like--- Q, R, F, L, I, K, etc.
If you fully depend on your CAD/CAM system and don't know basic code you also can't understand your CAD software.
Not to put you down, but if you can't write a simple G83 drilling cycle, then you need to stop with the CAD and go to your machines manual.
Good learning.
Mike
