585,975 active members*
4,394 visitors online*
    Sep 2012
    55
    How not to kill yourself with PVC!
    I've been happily cutting plywood (cheap) and acrylic (nice, but expensive). So I started searching for other things that I could safely cut, but at very little cost. The pound shop, or cheap stores like Ikea are often good sources of cheap things that can be re-purposed as raw material.
    It seems that most plastics are OK to cut, with the exception of PVC which apparently gives of Hydrochloric Acid when it's cut which damages your machine, and yourself! So probably best to avoid PVC then!
    So the question is, how to tell if something is PVC or not.
    If it has a recycling triangle on it, then 3 or V in the middle indicates PCV. But the triangle scheme is completely voluntary, so not everything has it.
    After some searching, I finally found this: isite.lps.org/gcooper/web/documents/IdentificationofPolymers.pdf by David A Katz. In his document, he details exactly how to identify a number of plastic type materials using very simple tests, all of which the home user should be able to carry out.
    So now you have no excuse for killing yourself (or your neighbour depending how long your fume extraction pipe is) by accidentally cutting PVC!
    It also gives off Chlorine gas that can be far worse than just the acid fumes
    cheers
    Dave
    Oct 2003
    927
    ID chart
    Here's a chart for identification
    Attached Files Attached Files
    Shoptask rebuild:
    http://www.cnczone.com/forums/showthread.php?t=2139
    Home built gantry router:
    http://www.cnczone.com/forums/showthread.php?t=5049
    Feb 2005
    469
    Here's a video showing the copper wire test.
  1. Anyone kill a G203V yet?
    By Mariss Freimanis in forum Gecko Drives
    Last Post: 03-27-2021, 01:48 PM
  2. X2 column mod- I went over kill!
    By chronic in forum Benchtop Machines
    Last Post: 04-05-2013, 03:47 PM
  3. New here. Please do not kill me
    By DMIINC in forum Community Club House
    Last Post: 08-07-2009, 04:52 AM
  4. Kill that Puppy,
    By CharlieM in forum Xylotex
    Last Post: 05-17-2005, 04:20 AM
  5. Big Red Kill Switch, where to get?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 03-23-2004, 05:42 PM
