585,597 active members*
3,492 visitors online*
IndustryArena Forum > CAM Software > CamBam > Mixing english and metric units in CAMBAM?
    Aug 2011
    It seems like the option for Drawing units only allows either inches or MM...does that mean that if i was to pocket a 30mm circle using a 1/4" router bit, I need to do set the Drawing units to either inch or MM, and do manual conversion for one of the two?
    It seems like this should be somehow configurable in the software...but I can find it. Any help/
    I don't use CamBam, but try using a 6.35mm bit. (1/4")
  1. metric english conversion
    By stude8 in forum Uncategorised CAD Discussion
    Last Post: 10-05-2012, 07:48 PM
  2. OSP 7000 Metric to English
    By bbarber80 in forum Okuma
    Last Post: 05-24-2012, 01:08 PM
  3. mixing english and metric tools
    By Joesph Jackman in forum Mastercam
    Last Post: 02-13-2012, 08:17 PM
  4. plans in metric units
    By onekk in forum Commercial CNC Wood Routers
    Last Post: 05-04-2010, 06:21 PM
  5. English or Metric?
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 04-30-2003, 10:49 AM
