585,959 active members*
4,793 visitors online*
Results 1 to 16 of 16
    Oct 2005
    332
    Full backup for later use
    Hello. I got a machine with a 21i-T controller.
    I do not want to regret later something that I did not backup in a machine, so I ask for a list of what is important to backup, before I start to change things. I searched in this forum but I did not found a clear reply. My objective is to backup everything that is possible to backup.
    Ladder - with ladder III software
    Parameters - with a card on boot, correct?
    anything else?
    Thank you very much.
    Feb 2009
    6028
    Ladder and SRAM backup. You can do both with just a card.
    Oct 2005
    332
    Quote Originally Posted by underthetire View Post
    Thank you.
    Aug 2011
    2517
    you searched? there's a thread about this exactly on the very first page of the Fanuc forum....
    http://www.cnczone.com/forums/fanuc/...do_i_need.html
    the Ladder III software is for creating/viewing and editing the ladder. you don't need to use Ladder III to backup the ladder in the machine. Using the correct procedure you can save it to a card plugged into the PCMCIA slot on the control panel. the ladder backup file is not human readable.
    you should also keep separate copies of the parameters and PMC parameters (they are just text files) for reference because the SRAM backup contains everything except the ladder and is not human readable either. if a parameter is accidentally changed you'll have nothing to refer to and you don't want to be wiping memory and re-installing the SRAM file just to fix one parameter because there's a big potential to screw the entire machine if you don't follow the correct procedure. with a separate copy of the parameters you can just look at the numbers.
    Oct 2005
    332
    Thank you,
    I really did not saw it.
    I managed to backup the SRAM without problems (one single file), now I entered in system data save and I have a few lines: NCBAsic, PMCAOPT2 and so on...
    Trying to backup any of those the CNC give:
    FILE SAVE ERROR. HIT SELECT KEY
    PROTECT FILE
    ... The file is protect even for reading it?
    There is any parameter that I should change in order to get access to it?
    Any direction is welcome.
    Thank you
    Oct 2005
    332
    I was able to save from the system data save the PMC-RA file. It was the only file that I was able to save.
    It is possible to save the remaining?
    NCBASIC
    PMCAOPT2
    PMC0BSC
    GRAPHIC
    DG2SERVO
    NC1 OPTN
    Like I told before I do not want to regret after. Because if anything happens them someone will tell me: You should backup that one before ...
    Mr FordAV11:
    How to get those from the CNC? Using also the card?
    I am sorry if the question was basic.
    Thank you
    Aug 2011
    2517
    PMC-RA could be the PMC parameter file or the ladder (check the file extension or open the file and view it with a text editor). If it's a lot of random junk characters it's the ladder. If it's a long list of numbers then it's the PMC parameters.
    The other items are system files that can't be backed up. I'm sure there is a secret password or access method for that but it's..... secret.
    To backup the parameters, go to your parameter screen (SYSTEM/PARAM) then page right until you see punch. Press PUNCH then ALL then EXEC (the exact button sequence may be different but you should be able to figure it out easily)
    You need to set your output device to 4 on parameter 20 (i.e. parameter 0020 = 4) if you want to punch to the card.
    Oct 2005
    332
    Thank you!
    Oct 2005
    332
    Just for others reference it is:
    System/Param -> (OPRT) -> Then screen right
    So now I got the Ladder (the .000 file in my case), the parameters and the SRAM. I am safe now?
    Aug 2011
    2517
    ladder should be auto-named PMC-RA.LAD. I don't know what .000 is.
    Oct 2009
    297
    Sram backup should have NC parameters, PMC parameters, PROGRAMS, Offsets, MACROS. You may backup each in edit mode using your card.
    The SRAM backup should be done with your axes in reference position and tool #1 selected in the turret. This way you will not have problems when adjusting the zero position of your turret if the turret has a fanuc servomotor.
    Regards
    Alex
    Dec 2011
    8
    hi fordav11......help me
    i have a cnc machine FANUC 21i, I want to save my data on the computer:
    SYSTEM DATA SAVE
    PROTECT FILE
    PLEASE HELP ME
    Aug 2011
    2517
    exactly which data are you trying to save?
    PMC parameters?
    Ladder?
    normal parameters?
    something else?
    Mar 2005
    816
    Which SRAM? I use a FANUC A16B-2201-13x SRAM card (up to 1MB) which works on the System 6??
    I know theres others...
    A20B-2902-0210
    A20B-3901-0942
    A20B-3900-0160
    A20B-3900-0052
    I still need to back up my 16MB. Everything else is pretty well backed up.
    Mar 2005
    816
    A20B-2902-0210
    A20B-3901-0942
    A20B-3900-0160
    A20B-3900-0052
    Apr 2009
    1379
    The SRAM BOOT back up takes care of ALL sram in the system that needs backing up. The SYSTEM FILES in the flash memory can also be backed up, but that has to be done by BOOting using two different function keys.
  1. Full backup of NUM 1060
    By Tiansen in forum Controller Cards
    Last Post: 04-08-2022, 10:30 PM
  2. BP VMC Backup
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2012, 01:23 PM
  3. Need to backup parameters on VF2 (USB)
    By jolulank in forum Haas Mills
    Last Post: 07-12-2011, 04:19 PM
  4. Parameter Backup
    By cncboy1 in forum Okuma
    Last Post: 11-18-2009, 07:52 PM
  5. SRAM Backup
    By msaiprasad in forum Fanuc
    Last Post: 12-06-2007, 08:04 AM
