585,589 active members*
3,258 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > High pressure coolant
    Nov 2012
    6
    I m working on Okuma LB251 - M lathe with OSP 7000L
    and i want to know how to turn on high pressure coolant
    i need someone to explain step by step
    kind Regards
    Aug 2011
    2517
    it's an option but if you have it....
    M142 Coolant Pressure Low
    M143 Coolant Pressure High
  1. Is high pressure coolant necessary?
    By RMW in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-11-2011, 07:46 PM
  2. Star ECAS32T High Pressure Coolant!?
    By pmrairokn in forum CNC Swiss Screw Machines
    Last Post: 09-21-2011, 08:29 PM
  3. High Pressure Coolant
    By davek11 in forum GibbsCAM
    Last Post: 03-17-2011, 04:08 AM
  4. High pressure coolant systems
    By CHAD LAWSON in forum MetalWork Discussion
    Last Post: 08-25-2008, 10:15 PM
  5. high-pressure coolant
    By 307startup in forum Mechanical Calculations/Engineering Design
    Last Post: 09-29-2007, 10:40 PM
