585,761 active members*
4,244 visitors online*
    May 2003
    109
    Mach3 External Estop Reset
    I am trying to find a hotkey or the abilty to reset an estop with an external switch. I don't see anywhere to assign a pin directly, is there a hot key to do it, that I can assign to a pin?
    I think this is how you do it. On the input page, set OEM Trigger#1 to your external switch. Then, on the hotkeys page, set the trigger #1 code to 1021.
    You might want to read through the customization Wiki at www.machsupport.com
    All the codes can be found there.
    May 2003
    109
    Worked like a charm! Thanks!
