586,000 active members*
5,073 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Surface Finish Problems
Results 1 to 6 of 6
    Jun 2012
    I'm having surface finish problem cutting Intraocular lenses. I use a .230 mm 2 flute end-mill to profile the lens. The problem is that portion of the chip remains attached to the upper edge of the lens profile. This lenses are made out of a special type of acrylic, which is soft and gummy. My theory is that sometimes I get batches of material that are softer than others so that the end-mill does not shear at exit of the part, but rather pushes the material. I also noticed that the end-mill flutes are course (the cutting edge is sharp, though).
    Any thought in this regard will be appreciated.
    Feb 2009
    6028
    Cutting any optics is a challenge. We can cut optics without the need for any second ops other than a final polish. Expensive equipment for sure!
    Sharp sharp sharp tools. I'd look at getting micro polished end mills. A little more but well worth it for what your doing.
    Apr 2006
    3206
    In addition to seriously sharp tools... perhaps even a fresh tool for that final pass... Climb cutting at the edge so the cutter is cutting into the body will help minimize a chip that shouldn't be there.
    Sep 2012
    1543
    Are you starting on the edge, or ending there?
    Jun 2012
    Quote Originally Posted by BAMCNC.COM View Post
    No, actually the tool plunges down and then profiles all around until it reaches the point where it plunged at the beginning. Much like a slot, one side in climbing and the other is conventional milling. The finish part is cut in climbing mode. Thanks.
    Jun 2012
    Thanks everyone for your thoughts, your're been helpful.
  1. Surface Finish
    By hartside in forum Mastercam
    Last Post: 12-05-2011, 11:49 AM
  2. Fadal 4020 surface finish problems. Help!
    By duane999 in forum Fadal
    Last Post: 05-12-2010, 02:22 PM
  3. 64 RMS Surface Finish?
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 01-13-2009, 11:19 AM
  4. Surface finish
    By skmetal7 in forum Mini Lathe
    Last Post: 09-10-2007, 06:56 PM
  5. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
