585,933 active members*
3,619 visitors online*
Results 1 to 3 of 3
    Jun 2012
    What is this sensor?
    Hi, I see this sensor on Sulzer g6200 textile weaving machine.
    It controls the warp thread tension. This sensor is called warp let-off sensor. What type of sensor can this be? Is this some kind of proximity sensor?
    Thanks.
    Mar 2011
    25
    If it controls tension I would assume it is some type of load cell.
    But warp tension ??? Is it mounted on or near a plasma conduit or Jeffries tube?
    (Okay I admit I'm a bit of a trekie)
    Dec 2003
    24221
    I would agree it appears to be a tensioner control.
    Here is an old patent for one that seems to explain the process?
    Patent US4546801 - Warp let-off control device for weaving machines - Google Patents
    Al.
    Albert E.
  1. Autofocus sensor
    By stekke_stim in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-16-2012, 03:13 AM
  2. orientation mag sensor
    By mkcherni in forum Want To Buy...Need help!
    Last Post: 12-30-2011, 02:16 PM
  3. Ohmic sensor
    By Bobbyr70 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-03-2011, 04:38 AM
  4. magnetic sensor
    By keithmech in forum CNC Machine Related Electronics
    Last Post: 07-29-2007, 12:04 AM
  5. non ARC height sensor
    By sunmix in forum CNC Machine Related Electronics
    Last Post: 11-05-2006, 06:51 PM
