I am looking at purchasing a CNC router, i have absolutly zero experience with CNC machines so i was hoping there would be someone out there on the WWW to give me some advice. I am going to post the specs on 2 machines i have been looking at both are the about the same price but on has a larger working are than the other. Any advice/ suggestions would be greatly appreciated. We would be working mainly with thin (1-3mm) aluminium sheet, but we would also like to be able to work wity polycarbonate sheet, and carbon fibe sheet.
Aluminum Sheet CNC Router (ZK-9015)
Items Description
Effective working area 900(X)mm*1500(Y)mm*150(Z)mm
Max. thickness of the materials ≤150mm(the distance between Z-axis and the bottom of the working station)
Materials Cast iron machine bed, cast aluminium gantry
Water cooling system Stainless steel water slot
Working table Aircraft aluminum T slot
Guide rail Linear round guide rail
Transmission Ball screw for X Y Z-axis
Driving mode Stepper motor
Spindle motor 1.5kw water cooling
Spindle speed 0-24000rpm/min
Empty traveling speed 0-8000mm/min
Engraving speed 0-6000mm/min
Resetting accuracy 0.05mm
Control system PCI NcStudio
Carving Instructions G code *Uoo *mmg *plt HPGL
Packing size 2160*1600*1650mm
Gross weight 450kg
SS CNC ROUTER WK6090
2.CE approved
3. aluminium, iron, wood, MDF
4. rotary or 4 axis workable
SS copper AL metal CNC ROUTER WK6090
Supply with CE certificate,
1) X,Y axis working area: 600 x 900mm
2) Z axis working area: <100mm
3) Table size: 940 x 1,120mm
4) Max. speed: 0 - 4,000mm/min
5) Max. Working speed: 0 - 3,000mm/min
6) Working delicacy: 0.02mm
7) Reposition accuracy: 0.05mm
8) Max. Feeding height: 110mm
9) Command: G code, u00, mmg, plt
10) Software: type3 software, Artcam software
11) Max. power consumption: 2.2KW
12) Spindle: 1.5kW variable speed, water cooled motor
13) Spindle speed: 24,000rpm
14) Work type: stepper
15) Weight: 200kg
16) Working voltage: AC 220V, 50/60Hz
17) Memory: 32M
18) Manner of receiving data: USB
19) Running circumstance temperature: 0 - 45°C
20) Relative humidity: 30% - 75%
