585,925 active members*
3,594 visitors online*
Results 1 to 8 of 8
    Dec 2011
    out of round condtion
    i have a mori NL2500 that i am turing spindles on. Tolerances are tight +/- .0127mm. The bearing surface furtheset awa from the main spindle continues to have an out of round condition. Seeing about .050mm. Having a big problem figureing this one out. Part is not tapered, spindles are dead on. any suggestions.
    May 2004
    4519
    Fix your work holding.
    Jun 2005
    142
    Ask a vague question, get a similar answer.
    What dia is the bearing and how far out is it?
    Is the spindle stepped or basically the same dia along its length?
    Using a chuck or collet?
    What material is it?
    DOC?
    Finish allowance?
    Can you use a tailstock or subspindle?
    Answer some of these questions and we can help, you might even fix it yourself...
    Dec 2011
    no steps or taper. Part is not physically round. Egg shape increases the farther u get away from the main spindle and closer u get to the sub spindle.
    2 bearing diameters - 66mm & 44mm - the 44mm is the one giving fits.
    Material is 4140 45~48 RC
    Microcentric collets
    Finish is 1.25 micrometers
    machine has a full sub spindle. We use a dead center with the spindles synced. Cant use a live center because our machine doesn't accpet independent spindle M codes.
    had Ellison come in an do a full alignmnet after we did it. They said the machine was dead on and in better alignment than most in the field.
    Feb 2009
    6028
    3 things come to mind...
    Bar is whipping in the main spindle-tighter liner
    or
    Hydraulic actuator is not aligned properly, causing the back of the spindle to walk(run out)
    or
    the rear support bearing on the spindle is loose/bad.
    Dec 2011
    not running bar stock - use cut to length stock
    yesterday i discovered that i can make test cuts all day long with no issues. But as soon and i unchuck the part on the sub spindle and rechuck on it, i see .030mm~.040mm of runout. Is this nornmal? Ellison says this is my problem. I can't say for sure. Sub chuck is brand new as is the collet.
    Feb 2009
    6028
    So, when Ellison checked alignments, did they check spindle centerlines between the 2 chucks? Do you see collet marks on the transfer material?
    Dec 2011
    Chucks check true between each other.
  1. Replies: 5
    Last Post: 04-16-2012, 09:25 AM
  2. A new round
    By lum in forum DIY CNC Router Table Machines
    Last Post: 10-01-2010, 11:53 PM
  3. 2D Contour on a round OD not very round :(
    By kojack in forum Mastercam
    Last Post: 08-11-2008, 01:07 AM
  4. Out of round on last cut
    By Robin Hewitt in forum Benchtop Machines
    Last Post: 08-18-2007, 01:20 AM
  5. round and round we go
    By omegaghost in forum Benchtop Machines
    Last Post: 01-10-2007, 05:25 PM
