585,717 active members*
3,811 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Jeep F134 to VW TDI adapter plate need F134 info
Results 1 to 6 of 6
    Jul 2010
    24
    Post Jeep F134 to VW TDI adapter plate need F134 info
    I'm looking to design an adapter plate for mounting the Volkswagen 1.9L diesel engines into Jeeps that originally used the F134 4 cylinder gasoline fueled engine. I have the neded infor for the VW engine, but still need the drawings and blueprints for the Willies engine.
    Jan 2006
    2985
    I've got some old service manuals for that vintage Jeep. I am not sure if they would have the bolt pattern called out though. I don't recall seeing it. Don't you have one you could trace and then reverse engineer?
    Matt
    Jul 2010
    24
    No I don't have the engines to work with, I'd like to draw up the adapter before I start collecting boat anchors in the yard.
    part of the touble I have found locating useful information about engines is the manufactures understandable do not release their master drawings.
    Quote Originally Posted by keebler303 View Post
    Matt
    Jan 2006
    2985
    have you talked to these guys?
    Adapter Kits | Advance Adapters
    Matt
    Jul 2010
    24
    yeah I did, no dice so far. thus why I'm still looking for the specs.
    Matt
    Jul 2010
    24
    Re: Jeep F134 to VW TDI adapter plate need F134 info
    while not a Volkswagen I did find this for old Jeeps, About
  1. RFQ- Need CNC Aluminum Transmission Adapter Plate and Starter Nose
    By vagmaster in forum RFQ (Request for Quote)
    Last Post: 04-30-2012, 03:15 PM
  2. 3 Jaw Chuck and Adapter Plate for 4th Axis
    By MetalShavings in forum Tormach Personal CNC Mill
    Last Post: 04-11-2012, 06:48 PM
  3. adapter plate
    By diycnc in forum RFQ (Request for Quote)
    Last Post: 02-07-2012, 02:31 PM
  4. adapter plate for 8x12 hf lathe
    By ubaldc in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2010, 09:03 PM
  5. 9x20 adapter plate
    By Pxsi in forum Polls
    Last Post: 10-04-2006, 11:32 AM
