586,000 active members*
4,834 visitors online*
    6855
    Solidworks to Slic3r
    Any tricks to importing a STL file from soildWorks to Slic3r? I keep getting errors.
    Upload the stl to Netfabb Cloud to fix it, only takes a few minutes and then you can download the fixed file.
    netfabb Cloud Service - Beta
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2005
    176
    Either that or download the "Basic" version of Netfabb studio. Unfortunately SolidWorks makes really faulty .STL files with holes and open edges. Netfabb Studio will import the STL and give you some options to repair it. After the repair you can replace the original SW STL with the one from Netfabb and print away! I think using the actual application is quicker and less hassle than the cloud service.
    I'm exactly the opposite, I use the Netfab app to split parts up but never had much luck fixing parts.
    The cloud does it easy for me and in almost no time.
    to each his own.
    Hoss
    Nov 2004
    69
    Re: Solidworks to Slic3r
    I found that importing them in to 123 Design or Sketchup and then saving as a STL works very well.
  1. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  2. CAD/CAM SLAM!: CAM for SolidWorks - CAMWorks for SolidWorks
    By cad_cam_slam in forum News Announcements
    Last Post: 06-15-2011, 03:42 AM
  3. Solidworks
    By KKM in forum Solidworks
    Last Post: 10-06-2010, 11:55 PM
  4. Webinar: New VisualMILL for SolidWorks Integrated CAM Solution for SolidWorks
    By Craig_Preston in forum Trade Shows / Webinars / Other Events
    Last Post: 07-16-2009, 01:03 AM
  5. Replies: 0
    Last Post: 07-16-2009, 12:43 AM
