585,761 active members*
4,163 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Looking for info on how to replace my CRT monitor.
    Dec 2012
    4
    I have a Fadal 2016 and I recently had a local company repair a spare monitor I had laying around, now it has come time to actually replace it and I was hoping someone could provide some insight/tips on how to replace this thing. Thanks in advance for any help.
    Jan 2009
    334
    Industrial TFT LCD and CRT Display Monitors
    Quote Originally Posted by WmGuildenstern View Post
    Try CNCZONE link; http://www.cnczone.com/forums/fadal/...d_monitor.html
    and, Industrial LCD Monitor and CRT Monitor Menu
    Hope this helps,
    Iron-Man
    Dec 2012
    4
    I'm switching a CRT for a CRT, I was looking for a parts schematic or tutorial on the change, but I do appreciate the attempt IronMan.
    Apr 2005
    345
    Toss the CRT, the flatscreens are less expensive, and reliable and its easy to do with any monitor or TV that accepts the yellow composite signal.
    http://www.scpconcepts.com
    Apr 2005
    1194
    LCD replacement on any machine is very easy however may require a signal change and an adaptor (BNC to VGA or BNC to HDMI or BNC to RCA on a fadal). You can purchase a DC powered signal changer for use with even LCD televisions. The older video boards only send a signal out less than 20mhz so they need a step up.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
  1. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  2. Looking for Info, Patent #'s, Info on Milling Machine Automatic Tool Changers
    By CNC-Joe in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2013, 05:41 PM
  3. I bought a J325 , monitor info
    By MadPickinSkills in forum Tree
    Last Post: 12-02-2010, 08:42 PM
  4. Fanuc monitor info
    By Dave3891 in forum Fanuc
    Last Post: 11-03-2010, 03:57 PM
  5. Monitor info needed
    By gridley51 in forum CNC Machine Related Electronics
    Last Post: 10-01-2008, 08:57 PM
