Does anybody know why I can't force any of my outputs on with the diagnostic window? The output number turns green, but the opto 22 relays do not turn on ( No red LED ). The same goes for the ICM2900 - I tried to force the output for the green and yellow lamps and nothing happens.
All of the inputs work fine. Opto 22 inputs are working and all of the push buttons are working on the Camsoft flat panel also. (All inputs turn green in the diagnostic pane when a switch or push button is actuated-opto input LED is on,etc ). I also tried a simple logic command with no results.
What gives?
Note:
Push a button:Opto 22 LED on: Input number green - Good
Turn on output in diagnostic windowutput number green:Opto 22 LED off
Turn on output in diagnostic windowutput number green: ICM no yellow or green lamp.
I'm missing something here.
Camsoft CNC Pro/Galil1842/Comtec PCI/O16/G4Opto22/ICM2900/WINXP
