i have read and searched around here, thought i would ask directly. i want to be able to cut jigsaw puzzles out of 3mm wood or plastic and i need precision with accurately repeatable results. i cant trust a die cut to be the same after its used up and replaced with another. because of this i plain to use a 36" plotter to print my images then glue/transfer them to my 3mm wood or plastic. 36" might be to big so im not holding to that if needed i can adjust. i feel a laser cnc cutter will provide the results i need but over the past few weeks i have not narrowed it down to one machine or even type. im not engraving or using 4axis and i will only ever cut the 3mm wood or plastic with it. but need to produce them to a good size. was hoping 36x36 or 36x24 so i can adjust if needed.
need help to understand the type of laser i would need
also a large table type cnc machine? type? style? name? brand?
thanks for any help
