Originally Posted by
ihavenofish
it depends on your target market.
mach3 is universal and flexible, easy to use, easy to support, and easy to get support. i can come all in with a pc for under $300, or ou can flesh it out for several grand.
its NOT remotely the best system out there, but its a no brainer for hobby builds.
so when you try to target a control panel to this low cost hobby market, you are starting at the bottom of a big mountain. panels like the gsk are interesting, but the retail price (1500-3000 typically) is hard to justify, when it appears on the surface to have no obvious benifits over mach3, and no online users to guide you along the way.
the next jump up is something like an accurite 3500i made by heidenhain. these guys have support, and a reputation, and the control itself has very obvious and genuine advantages over mach3. trouble is, the retail price of the panel alone is more money than most hobby level conversion mills, and with a full on kit with wiring, small ac servos and drives, and accessories, youve broken 10k handily. this is a control after all that would boost the performance of a hass, so its on a very different level.
so the under 10k crowd, thats a mach3 solution crowd. the over 10k crowd, thats a group that needs work done, and will pay for a real solution.
i do think though that the 1st person to make an all in mini panel control thats as flexible, and genuinely better than mach3 for under a grand is going to be very rich.
with the current cost of tablets, sub notebooks, and prototyped circuits... i dont think this is far away either.
