585,974 active members*
4,338 visitors online*
    Nov 2008
    7
    problem with my LinuxCNC
    Hello I have a problem with my LinuxCNC
    I run the "LinuxCNC Stepper" I complete my setup and I test each axis separately, it works very well,
    Once I finish the configuration and I run the shortcut created on the desktop, I can no longer control my axes.
    Another note: when I launch the shortened engine is released, as if I hit the power
    Someone has already experienced this problem?
    thank you for helping me
    Feb 2007
    711
    there are 2 buttons on the top left of the screen. click the left, then right one.
    left one is "toggle emergency stop" shortcut F1
    right one is "toggle machine power" shortcut F2
    hopefully that is your problem.
    Otherwise did you have to set up a charge pump?
    tell us what hardware you are using.
    Nov 2008
    7
    I already remove the emergency stop and I put the machine
    I just use a map interface HY-JK02-M 5
    driver and stepper motor wantaiMOTOR
    Apr 2005
    16
    Re: problem with my LinuxCNC
    i just setup my linuxcnc whit hy-jk02-m board and working fine drivers have hy-vin268n-5A, only speed have cslow if make acceleration up 15mm/sec lost step. mach3 not working anything good, if bush button Y move X and y sametime or stay motors run. i no know why but i instal linux and now working fine first test have ready and carwing "linuxcnc" text yesteday fine. but how i can move etc, spirar , example in to working area box (have in display red line) have out of working area alltime ? why and how move ecample g-gode to in area ?
    and were found now 3 axis 7-segment dispaly this board ? and hand manual controll box who can set speed, axis up /down manual and other buttons what this need, or were have diy project how build hand wheel and button box ?
  1. LinuxCNC 2.x Laser component problem
    By john1a in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2016, 11:47 PM
  2. Linuxcnc 2.5.2 won't run
    By cpeter in forum LinuxCNC (formerly EMC2)
    Last Post: 04-24-2014, 12:54 PM
  3. LinuxCNC with servos.
    By Linksauce in forum LinuxCNC (formerly EMC2)
    Last Post: 12-25-2013, 01:11 PM
  4. linuxcnc settings
    By cotang in forum Momus Design CNC plans
    Last Post: 09-10-2012, 07:17 AM
  5. LinuxCNC right for me?
    By punisher454 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-18-2012, 04:56 AM
