Hi need help with rhinocam 2 near coventry England if you can help please call steve on 07775604191 or email s.brindle @ fsmail.net
Have you watched YouTube tutorials on rhinocam? The software maker has a lot of videos on YouTube aswell as they make many cam softwares that are basically identical to rhinocam.
Yes seen all videos do the same but when I put cut levels in it shows it digs in to the job where I don't wont it to any ideas
Like on an edge of a hole or something? It can do with entry exit strategy, does it say 45 degrees? Put it to 90 or try another entry exit strategy, also depending on the cut certain actions in hole pocketing will do that and others, keep simulating the cut after you mess with settings, you will eventually come to see that you won't use half the settings, like cleanup passes, etc.
if you need chat help add me on skype
skype : alkubabji
i can help you with rhino and rhinocam.
