I just received my Gecko G540, and have read numerous posts on setting up limit switches. I want to use two limit switches for the X and Y axis and one for the Z axis.
I realize I should use the NC option on my micro limit switches, but does some one have a diagram of how to hook two up in a loop to have them mounted at X+ and X- (Pin 1 On The Gecko), and (Y+, and y- Pin 2 on the Gecko) Z would of course use pin 3 on the Gecko.? I want to have pin 4 on the gecko for a touch plate.
I was also wondering if I wire the switches the way I described above if I can also use them as home switches?
I appreciate everyones advice, thank you in advance.
