586,000 active members*
4,747 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Larken > Larken 20-20 X is changing between cuts.
    Dec 2012
    We have a Larken 20-20 that is not positioning itself in the correct X position for subsequent cuts. Proportions of the cuts are fine, but it is mis-aligning, for instance, the first and second 1/16" depth cutting passes.
    Also, when cutting letters, it may cut the second letter too near or on top of the first letter.
    We are using mastercam x6 and starcnc usb 3.04
    Any help would be appreciated.
    Feb 2007
    966
    I had a problem with some of the controller chips in the USB controller. I switched from the 18F452 to a 18F45K22 and there was a bug that crept in.
    Send me an email , and i will send out a new chip.
    Larry
    Dec 2012
    I have received the new controller chip and will be installing it before the weekend.
    I'll keep you posted as to how it goes.
  1. Larken is still
    By cncadmin in forum Larken
    Last Post: 12-16-2008, 04:23 AM
  2. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  3. New Used Larken 24/24R
    By Arcticfox46 in forum Larken
    Last Post: 06-20-2007, 05:47 PM
  4. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
  5. Larken
    By CNC Pro in forum Larken
    Last Post: 02-12-2004, 02:14 AM
