How do I fix the problem of my printing starts over ejecting plastic? Is their a setting to change the time the printer head starts to eject plastic and starts to traverse? I'm using the ini config and .5mm tip.
Tell it .4mm tip, and make your retraction more, what software are you using, I have a slicer config file I could send you tonight for your exact printer. Pictures help describe your problem better too.
The file would be great
Hi CNCadmin,
Have you tried the point5mm.ini file found here? Index of /AO-100/software/2012-Q2/configs/slic3r
You can also try the .ini files for slic3r found here
Index of /AO-101/software/current/slic3r/config
Filament Retraction should be set to 1.4mm - 1.6mm depending on how fast you are printing.
If you have any questions or comments, please feel free to ask.
Best Regards,
Jon Fye
Sales Associate
[email protected]
1-970-377-1111 x633
Aleph Objects, Inc.
123 SW 12th Street
Loveland, Colorado 80537
United States of America
Hi CNCadmin,
ok I will wait for the picture(s)
Best Regards,
Jon Fye
Sales Associate
[email protected]
1-970-377-1111 x633
Aleph Objects, Inc.
123 SW 12th Street
Hi CNCadmin,
Are you printing just one object at a time? Also, what speed are you printing at? If you are printing jsut one object on the heatbed at a time you might try adding another object to the print job to allow more time for each layer to cool before the next layer is applied.
Best Regards,
Jon Fye
Sales Associate
[email protected]
1-970-377-1111 x633
Aleph Objects, Inc.
123 SW 12th Street
I was just printing one. I'm using the stock settings.
Which stock settings, ours or the stock ones in Slic3r itself? Also which version of slic3r? If you could point at the URL of the .ini you are using, that would be nice.
Jon actually pointed at two different stock settings. The one for 0.8.4 (the top URL) and 0.9.7 (the bottom URL, which is the latest slic3r version). I would suggest using the latest/greatest release of slic3r and this config, just to be clear:
http://download.lulzbot.com/AO-101/s...zl_pt4-lyr.ini
It basically looks like it is extruding too much material. You can adjust this by lowering the extrusion multiplier (Filament Settings-->Filament). You shouldn't have to adjust this though--there may be something else up with the settings (e.g. you have Slic3r's defaults, not ours, for instance).
Also, feel free to paste your .ini somewhere and we can take a look at it.
If the part is really small (which it kind of looks like), it can also be helpful to print multiple copies on the same plate. This allows it to cool down more between layers.
-Jeff
I have a AO-101 not the 101
acceleration = 0
bed_size = 200,200
bed_temperature = 0
bottom_layer_speed_ratio = 0.75
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 40
complete_objects = 0
cooling =
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 5
duplicate_grid = 1,1
end_gcode = M140 S60 ; turn down bed\nG1 X0 ; home X axis\nM18 ; disable motors
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width_ratio =
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 2.89
fill_angle = 35
fill_density = 0.75
fill_pattern = line
first_layer_bed_temperature = 0
first_layer_height_ratio = 1
first_layer_temperature = 0
g0 = 0
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 50
infill_every_layers = 1
infill_speed = 90
layer_gcode =
layer_height = 0.25
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
notes =
nozzle_diameter = 0.5
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 25
perimeter_speed = 60
perimeters = 2
post_process =
print_center = 85,80
randomize_start = 1
retract_before_travel = 1
retract_length = 1.4
retract_lift = 0
retract_restart_extra = 0
retract_speed = 25
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 20
small_perimeter_speed = 60
solid_fill_pattern = rectilinear
solid_infill_speed = 90
solid_layers = 3
start_gcode = G28 ; home all axes
support_material = 0
support_material_tool = 0
temperature = 0
threads = 2
travel_speed = 150
use_relative_e_distances = 0
z_offset = 0
do I need a fan on it?
http://download.lulzbot.com/AO-100/s...onfigs/slic3r/
It appears you are using the config for the 0.8.4. This is ok, but slic3r has had vast improvements since then. I suggest using the latest 0.9.7 version of slic3r, freely available at slic3r.org and use this config:
That is what shipped with the AO-101 (you have AO-100), but they can use the same slic3r config. We also have a finer resolution version of the config for 0.5mm nozzles in the same directory:
http://download.lulzbot.com/AO-101/s...zl_pt3-lyr.ini
I suggest giving that a test and also printing multiple parts on the same plate, which helps when printing small parts (which from the photo, it appears your part is).
Thanks, and if you have any other questions, feel free to ask.
-Jeff
working great now!
