584,854 active members*
4,379 visitors online*
Results 1 to 8 of 8
    Jan 2012
    XZero Raptor 30"x36" Build
    So, I'm going to start this build thread to document it, but also to get help as I need it.. I don't think I have all the parts yet, so I guess we'll start there!
    Here's what I have so far. I've emailed George to find out what's missing. There was never a complete list of what I should be getting, so I'm not 100% sure what to expect that's not here. I don't seem to have a screw for the Z axis, at the lease, but it looks like the chains for organizing the wires and such are missing too. There might be some other misc. pieces/parts missing as well, but I've received about 3 or 4 various larger shipments and 1 or 2 small ones.
    Thanks in advance for everyone's input and assistance!
    Attached Thumbnails Attached Thumbnails IMG_1541.jpg   IMG_1542.jpg   IMG_1543.jpg   IMG_1544.jpg
    Apr 2011
    178
    Hurry..
    I want more...
    Dec 2014
    41
    Re: XZero Raptor 30"x36" Build
    Any pics of the final assembly?
    Dec 2014
    41
    I understand the braces in the middle have to be ordered. 1x3 or 1030 and the Mounts are 6 hole button head M6-12 threaded.
    24 Long 1x3 592mm
    36 Long 1x3 892mm
    48 Long 1x3 1192mm
    60 Long 1x3 1492mm
    The only missing answer for me is if the attached bracket will work or not. It is from Tnutz.com. The extrusion is available in any custom length from 8020inc on eBay.
    ATTACH=CONFIG]269746[/ATTACH]
    Attachment 269748
    Attachment 269750
    Jun 2014
    8
    I hope that bracket works, it's the same one I ordered ;-)
    Dec 2014
    41
    Quote Originally Posted by Spikec View Post
    Let us know! I see on the Tnutz website they offer a "slotted" version (on one side) as well. Might be a better option for a little wiggle room.
    Dec 2014
    41
    Thanks for the brackets suggestions! Worked great! Just need to figure out the easiest method for attaching the slotted aluminum panels and my build it complete and ready for testing. The 2'x2" angled aluminum is going to be quite a bit of work to get right since it will all have to attach from the bottom. I am thinking of just countersinking screws from the top to t-nuts in the 8080 profile. The Weatherpack connectors worked great as well!
    May 2008
    4068
    Quote Originally Posted by firewire View Post
    You can get machine running and use it to slot the angle . It should work good to countersink the holes from the top to the 8080 profile. Before when I used the 8020 profile it always caused the top to bow . With new profile it is very flat and straight
    XZero cnc
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Build Log: RMGVideos XZero Raptor Build
    By sagreen in forum DIY CNC Router Table Machines
    Last Post: 05-10-2011, 09:00 PM
  4. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
