Has anyone modified the door on one of these machines? The problem is the door does not move back far enough and fouls the area that you would normally use to tighten the chuck. This means thta you have to tighten the chuck in the horizontal position which then leads to the chuck key being dropped and damaging the z rails. I cant believe these machines are made with this design flaw. I was thinking of grinding a slot in the panel so that the door can move right back but then the door will drop. Any ideas?
