Hi
Im using Heidenhain itnc530 control on 5axes mill (but milling in 3 axes here)can anyone tell me if I datum shift in z axes +80mm Abs in main program
then call a sub programme and write the same datum shift z+80mm in Abs not inc- as a safety at every tool call will it stay at 80mm or keep adding
to shift amount. so I can run a tool after re probing it at any point within the sub programme by going to the sub programme call line in main then
goto whatever toolcall line is needed so the shift does not get missed and mc crashes the -80mm in z -not tried it but i would hope it stays absolute -any
experience would be apreciated.
