I use the fogbuster system for coolant for my machining. It's worked really well all these years. Now that I am getting the Tormach 770, I'm really looking forward to the tool changer and not having to change tools all the time. However, I have realized that there seems to be one thing that is still not automated, and that is the coolant position.
I can build a simple device to aim the fogbuster coolant nozzle, but the position of a servo still needs to be controlled by the computer. I asked Tormach if there was any extra input/outputs to use with a programmable coolant system and was told with all the accessories that I have for my machine, that all the inputs/outputs are maxed, and that I should ask on the forum how to add additional input/outputs to the controller in order to use a programmable coolant, as a few people have added stuff like this to a Tormach mill.
That being said, does anyone have any idea how to do this? I have one idea, and that is to add another parallel port card to the controller, and just add the necessary stuff via another parallel port.
Another idea is a programmable input/output card that uses a usb port, similar to how the Tormach ATC works (from what I've read so far).
Has anyone does this? If so, what did you do?
Thanks much,
Wade
