585,605 active members*
3,308 visitors online*
    Aug 2010
    11
    Turbo Pmac and NC software
    Hello everyone! I build milling machine and choosen Turbo Pmac ISA board for control. Two axis are gantry. Machine partially made from concrete. Main stage is iron. Machine is large, near 2.5tonn.
    [ame=http://www.youtube.com/watch?v=pUJw6m5uZWc]Видео0012 - YouTube[/ame]
    All axis are tuned.Machine Limits enabled.
    I used NC Pilot to generate project with simple tunings. I disabled control panel and used software panel. Lookahead is disabled. DPram active. In first tests got messages, like Axis are not referenced. Now all axis are referenced and go to home position. When i turn on Start bottom (Auto mode and MDI mode) nothing work. Just axis are moved via Jog bottoms in Manual mode. How to run G code execution? What i made wrong. Software is NC5. Very hope to your help. Thank you! Alex
    Attached Thumbnails Attached Thumbnails Pict0282.jpg   Pict0285.jpg   Pict0234.jpg
    Attached Files Attached Files
    Sep 2007
    Go to Äîêóìåíòàöèÿ. Delta Tau Может поможет
    Re: Turbo Pmac and NC software
  1. PMAC NC v2.36 Integration help needed
    By serickson in forum Controller Cards
    Last Post: 06-26-2011, 08:09 AM
  2. which CNC controllers use PMAC-LITE ?
    By josh591 in forum Controller & Computer Solutions
    Last Post: 04-30-2009, 09:21 AM
  3. Is CNC Turbo Software good for Haydon steppers
    By zflyer in forum Servo Motors / Drives
    Last Post: 06-24-2008, 01:52 PM
  4. EZ PMAC software
    By gridley51 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-13-2008, 10:05 PM
