I have had problems getting SC7 to recognize the safe height I set in the program.
I just discovered that turning off the fast calc method window in the miscellaneous tab fixed the problem.
This was on a multiple hole waterline operation and if the cutter was set right on zero it would skim the part when traversing to the next hole (not recognizing the safe height), I got around it by raising the cutter zero point a few thousanths to ensure that it would clear the part as in this case it was a straight sided hole and this would work.
This problem would show up on some holes but didnt always happen, some holes the safe height was as it was set in the program, others it wasnt there.
Anuyone have problems with this?
